8.18.12015-07-23
PlanetPress Image
PlanetPress Image output tasks are used to make request to PlanetPress Image, which creates image files which it then archives or emails. Since this task is an output, it is not possible to immediately act on the generated image before continuing. When necessary to immediately retrieve the generated file, Digital Action should be used instead.
In addition to the job-specific PlanetPress Image properties you configure in the task’s properties dialog box, there are configurable options common to all PlanetPress Image outputs processed by a given computer (see PlanetPress Image User Options). Note that those options are specific to each PlanetPress Image installation and that they are immediately applied.
The following describes the properties specific to PlanetPress Image output tasks. For information on those properties shared by various types of tasks, such as Other and On error properties, refer to Configurations, Processes and Tasks.
In some combinations of Microsoft Outlook and Windows versions, it is not possible for Outlook to be opened while PlanetPress Workflow is running, so emails are not sent out automatically. To correct this, make sure to logon to Windows on the PlanetPress server using the same login that PlanetPress is using, and open Outlook before starting the PlanetPress services. You could also use a startup process to start Outlook before the rest of the services.
Any data file with a valid Emulation, or an Optimized PostScript Stream file (.ps) generated by PlanetPress itself.
The .ps file must be the result of the merge between a PlanetPress Design document and a data file, and can be generated either with the use of Add Document, or a printer queue using a Send to Folder Printer Queue. Postscript generated using any other way will fail, as PlanetPress Image requires knowledge of the number of pages in the document, which is not available in output generated using any other means. Note however that Digital Action does have the ability, in most cases, to generate output using third-party postscript files.
Processing & Output
Multiple things can happen, depending on the options chosen and the type of data this task receives:
Task Properties
General tab
Job Options tab
If you chose PDF as the output type in the General tab, use this tab to choose the appropriate PDF options. Note that all the options available in this tab are only used with PDF files.
PlanetPress Search Database tab
If PlanetPress Workflow is configured to automatically update a PlanetPress Search database (see PlanetPress Image User Options), this tab can be used to override the global settings so that the task updates a different database than the one set in that global configuration. In order for the settings to work, the Add PDF to PlanetPress Search database must be checked. However, you can override which database will be updating using the option in this window, Override global PlanetPress Search Database settings. The database options then activate.
Login, Recipient, Attachments
