8.18.12015-07-23
Search and Replace
Search and Replace action tasks are used to locate and replace strings of data within the job file and to replace them with other strings of data. Note that this action task cannot be used with binary files.
For more advanced search and replace functionality, you can also see Advanced Search and Replace.
Any text-based file can be used in this task, even formats that are not directly compatible with PlanetPress. As long as the text is visible in a text-based editor (such as Notepad), it is readable and supported by this task.
The appropriate changes are made to the data file (replacing text).
The modified data file is output from this task. Metadata is not modified in any way if it is present.
Search and Replace action task properties are as follows:
Common Errors
Comments Tab
