8.18.12015-07-23
HTTP Server Input User Options
HTTP server input user options control the server protocol aspects of the PlanetPress WorkflowHTTP Server input tasks. This is where you enable and configure secure communication for the HTTP Server.
By default, the request XML also contains a CDATA section which contains the raw input data, effectively doubling the size of the incoming file. Due to technical restrictions, the incoming XML file cannot be more than 400MB, which because of CDATA is reduced to around 200MB. To help in this situation, you may elect to omit CDATA from the attachment in this dialog. Please note that this limitation also affects incoming binary files (sent through file upload in a form), regardless of CDATA settings.
The available HTTP Server user options are as follows:
SSL is used to accept secured, encrypted requests from web clients and requires a certificate delivered by an approved authority. SSL can also be called HTTPS, though that is a misnomer. For more information on SSL and how to purchase a certificate, please see Q10694 on SSL.com.
