8.18.12015-07-23
Output to SharePoint
The Output to SharePoint Action Task can be used to send files to an existing Microsoft SharePoint server.
Any data file, with optional metadata.
The task connects to the selected Document store and uploads the current data file. If the file already exists, it will be overwritten and, if this option is selected, marked as "checked in". The information accompanying the file (the SharePoint metadata) is either updated or created.
The output of this task is the original data file.
Task Properites
Configure SharePoint Metadata Fields dialog
This dialog lets you setup the information you want to assign to the SharePoint Metadata information. It contains one line for each field present in the SharePoint document library.
Document libraries using the Content Type system in SharePoint 2007 and higher (as well as Windows SharePoint Services 3.0 and higher) are supported in PlanetPress Suite 7.4 and higher only.
Connection Tab
Examples & Use Cases
Common Errors
Comments Tab
