8.18.32016-03-14
PlanetPress Workflow Printer Queues
The printer queues displayed in the Configuration Components Pane of the PlanetPress Workflow Configuration program are not to be confused with Windows printer queues. When you start building a PlanetPress Workflow configuration it contains no printer queues so you have to create queues and set each one’s properties.
The PlanetPress Workflow Configuration program lets you create four types of printer queues:
The properties associated with each queue will differ depending on the queue type. In the case of an FTP Output printer queue, for example, the properties include the IP address of the FTP server. In the case of a Windows Output printer queue, on the other hand, you will find the name of a local or shared Windows printer queue.
To send print jobs to any of those PlanetPress Workflow printer queues, you must use a Printer Queue output task. Note that with a single task, you can send print jobs to multiple printer queues, regardless queue types.
