8.18.32016-03-14
Email Input
Email Input retrieves email data through a Microsoft Outlook or POP3 connection.
If Microsoft Outlook connection is used, Microsoft Outlook 2000 or higher must be installed on the computer where PlanetPress Workflow is located.
Email Input captures all emails and their attachments from the selected inbox, when those emails correspond to the rules defined in the General tab. If no rule is defined, all emails in the inbox are retrieved. Emails retrieved using POP3 are deleted from the server, emails retrieved from an Outlook inbox are moved to the Deleted Items folder by default.
Depending on the options selected below, each email is converted into a text-only data file, and each attachment is separated from the email.
Depending on the options, each email is sent as a data file, followed by each of its attachments sequentially.
If you use Email input tasks to capture data encoded using a Double-Byte character set (such as those used for Japanese or Chinese, for instance), it is preferable to use attachments rather than the email body to carry the data from its source to the input task, as data corruption is less likely to occur using this method.
Email input task properties are as follows:
General tab
Login Tab
"Other" Tab
Job Information definitions
Because of the way Microsoft Exchange works, when receiving an email from a user on the same local Exchange server, the email address may not be available. See FAQ-1509 in the Knowledge Base for details.
Common Errors
Comments Tab
