8.18.32016-03-14
Add/Remove Text
Add/Remove Text action tasks can be used to perform the following actions on the data file they receive:
Note that the content must be located at the beginning or the end of the data file.
Any text-based file can be used in this task, even formats that are not directly compatible with PlanetPress. As long as the text is visible in a text-based editor (such as Notepad), it is readable and supported by this task.
The selected operation (adding or removing lines, text or pages) is made on the data file.
The modified data file is output from this task. Metadata is not modified in any way if it is present.
Add/Remove Text action task properties are as follows:
General tab
Common Errors
Comments Tab
