8.18.32016-03-14
Rename
Rename action tasks are used to rename the job files they receive. Note that you can see how each file is renamed via the Object Inspector when stepping through a process in Debug mode.
Any job file, in any format.
The task renames the job file to the desired name, and changes the value of %f and %F to reflect the new name.
The input data file is output, with the new name.
Rename action task property is as follows:
General tab
Common Errors
Comments Tab
