8.18.32016-03-14
Saving and Sending a Configuration
The core of the PlanetPress Suite workflow tools is the PlanetPress Watch service which, once started, constantly runs in the background to perform the tasks included in its current configuration file. PlanetPress Workflow lets you create, edit and save configuration files.
As you are working on your configuration, you can save that configuration file as a file on your local hard drive with the pw7 extension (see Save your Configuration).
Saving a configuration file never replaces the current PlanetPress Watch service configuration. To do this, you must use the Send Configuration command (see Send your Configuration).
