8.18.32016-03-14
Create PDF/VT
The Create PDF/VT, similar to the Create PDF task, creates PDF/VT files from a PlanetPress Document. This PDF/VT is compatible with the Create Print Content directly without the use of a Connect Template (PDF/VT mode).
Any data file supported by the selected PlanetPress Document.
The input data file is merged with the selected PlanetPress Document.
The output is a PDF/VT with default quality settings. The metadata embedded within the PDF/VT is the one generated by the PlanetPress Document.
Properties
The Create PDF/VT Action Task properties are as follows (note that the "Connect Proxy" tab is not present as this task does not communicate with the OL Connect Server module):
Common Errors
Comments Tab
