8.18.32016-03-14
Merge Jobs
The Merge Jobs Action Task merges an external metadata file containing an OL Connect Job with the current job file.
The task must receive a Job metadata file, which is output from the Create Job task. The selected metadata file must also be the output of a Create Job task.
The current metadata file is merged with the selected external metadata file.
The task outputs a merged Job metadata file which can be used in the Create Output task.
Properties
The Merge Jobs Action Task properties are as follows:
Common Errors
Comments Tab
