Adding Tasks
You can add as many tasks as you want to your process by using the Plug-in Bar in PlanetPress Workflow program.
To insert a task:
- Open the Plug-in Bar by clicking on its tab. If you can't see the Plug-in Bar tab, click on the View tab in the Ribbon and make sure the Plug-in Bar is highlighted in the Show/Hide section.
- Locate the task you want to add to your process. You can navigate between the different task categories by clicking the icons at the bottom of the Plug-in Bar.
- Using your mouse, click and drag the task in your process at the place you want to insert it.
- Depending on where you place your mouse, you may see that you can replace or insert existing tasks, or not place it at that location at all.
- When you drop the task in the desired location, a dialog box containing the available task properties is displayed.
- Set the task properties as required and click OK to close the dialog box.
There are a few things to keep in mind when dropping tasks:
- You can insert input tasks anywhere in the process except in output task locations.
- When you add an output task, a new branch leading to that new task is added above the selected task or branch, except when replacing an existing output task.
- Dropping a task on top of another one replaces it.
- Dropping a task between two tasks will insert it at that location.
- You cannot add a task above the initial input task of a process, since new tasks are always added above a selected task or branch.
