Set this variable to 1 (true) or 0 (false) in order to return a true or false status to PlanetPress Workflow, when using your script as a conditional branch. This variable will have no effect if the script is run as an action.
Example
This example will always return true, as the condition is static. It is, after all, simply an example. You get the idea.
Dim everythingOK everythingOK = true if (everythingOK = true) then Script.ReturnValue = 1 else Script.ReturnValue = 0 end if
var everythingOK;
everythingOK = true;
if(everythingOK = true){
Script.ReturnValue = 1;
} else {
everythingOK = True if everythingOK == True: Script.ReturnValue = 1 else: Script.ReturnValue = 0
$everythingOK = true;
if (everythingOK = true) {
$Script->{ReturnValue} = 1;
} else {
$Script->{ReturnValue} = 0;
