Select Image dialog
The Select Image dialog lets you select an image, depending on where the image is located. Whenever possible, a preview of the selected image will be shown.
- Click Resources, Disk or Url, depending on where the image is located.
Resources lists the images that are present in the Images folder on the Resources pane.
Disk lists image files that reside in a folder on a hard drive that is accessible from your computer. Click the Browse button to select a folder (or an image in a folder).
As an alternative it is possible to enter the path manually. You can give a local path (e.g. C:\Images\Test.jpg) or use the "file" protocol. The complete syntax of a fully qualified URL with the "file" protocol is:file://<host>/<path>. Note: if the host is "localhost", it can be omitted, resulting infile:///<path>, for example:file:///c:/resources/images/image.jpg.Url lists image files from a specific web address. Select the protocol (http or https), and then enter a web address (for example, http://www.mysite.com/images/image.jpg).
Note: If a URL doesn't have a file extension, and the option Save with template is not selected, the Select Image dialog automatically adds the
filetypeparameter with the file extension as its value (for example:?filetype=pdf(if it is the first parameter) or&filetype=pdf).
Thefiletype,pageandnopreviewparameters are not sent to the host; they are used internally. Therefore, URLs that rely on one of these parameters cannot be used. -
With an external image, you can check the option Save with template. If this option is checked, the file will be inserted in the Images folder on the Resources pane at the top left.
If it isn't saved with the template, the image remains external. Note that external images need to be available when the template is merged with a record set to generate output, and that their location should be accessible from the machine on which the template's output is produced. External images are updated (retrieved) at the time the output is generated.
