Send to Workflow dialog
The Send to Workflow dialog sends selected templates, data mapping configurations and Print Presets to the PlanetPress Workflow server.
Configurations: Initially this list contains the Connect template and data mapping configuration that are currently open, and the Job Creation Preset and Output Creation Preset that were last modified.
Browse: This button opens the Select Files dialog that lets you add one or more templates, data mapping configurations and Print Presets to the list.
Tip: Actually, the path may not begin with 'C:\Users', as this is language-dependent. On a French system, for example, it would be 'C:\Utilisateurs'.
Type%userprofile%in a Windows File Explorer and press Enter to open the actual current user's home directory.There are two ways to make it easier to find the file that you need:
The Show drop-down list lets you select the type of preset that you want to open.
In the Filter field, you can enter (part of) a preset name to filter the list for matching presets.
Select Preset: Opens the Select Preset dialog. This dialog lists all Print Presets found in the folder:
C:\Users\[UserName]\Connect\workspace\configurations. Where[username]is replaced by the appropriate Windows user name.Select one or more Print Presets to add them to the list of configurations in the Send to Workflow dialog.Delete: Deletes the selected file from the list of files to send.
Workflow Server: Use the drop-down to select where to send the files. This lists all the detected PlanetPress Workflow installations detected on the network.
Note: If Workflow is installed on another computer, Workflow must be configured to accept files coming from another host (via the Access Manager).
The Messenger service, which is used for inter-module communication, uses ports 5863/5864 by default (see Firewall/Port considerations). -
Send:Sends all selected Connect files to the selected Workflow Server. You can use the topmost checkbox to select all of the listed files at once.
Cancel: Click this button to close the dialog without sending files to Workflow.
