Style sheets dialog
The Stylesheet editor dialog is used to edit CSS style sheet resources. For information on the use of style sheets, see Styling and formatting and Styling templates with CSS files.
This dialog lets you edit the Global style sheet (context_all_styles.css, which by default applies to all contexts), and the style sheet that applies to the context that is currently being edited in the workspace: Print (context_print_style.css), Email (context_email_style.css) or Web (context_web_style.css). It also allows to edit any stylesheets imported with a Word file.
To open this dialog, select Edit > Stylesheets....
Scope: Use the drop-down to select Global (all contexts) or the context that is open in the workspace, such as Print. Selecting a context shows all it's CSS rules in the Rule List.
Show: Use the drop-down to select whether to show all CSS rules or limit to certain types: Class, ID or Element rules.
Rule List: Displays the list of rules in the currently selected style sheet.
Rule Display: Displays the contents of the currently selected rule in the Rule List.
New: Click to create a new rule with the Edit Rule dialog. See New/Edit Rule dialog.
Edit: Click to edit the currently selected rule in the Rule List using the Edit Rule dialog. See New/Edit Rule dialog.
Delete: Click to delete the currently selected rule in the Rule List.
Duplicate: Click to create a duplicate of the currently selected rule in the Rule List using the Edit Rule dialog. The default name for the new rule is the name of the current one plus "-duplicated". See New/Edit Rule dialog.
Move Up: Move the currently selected rule in the Rule List up one position in the list.
Move Down: Move the currently selected rule in the Rule List down one position in the list.
Save: Click to save all changes to the style sheet and close the dialog.
Cancel: Click to close the dialog without saving any changes.
The New/Edit Rule dialog shows the properties for a specific CSS selector.
Click the Apply button to see how a setting affects the elements that are subject to that selector. (You may have to move and resize the Stylesheet dialog before opening the Edit Rule dialog, in order to be able to see the template that you are working on.)
At any point you can click on the Advanced button to see the Advanced Stylesheet Rule. See Advanced Stylesheet Rule.
- Name: The CSS Selector to which this rule applies. This can be a selector that is specific to Connect (see Selectors in OL Connect) or any selector used in regular CSS, since they can also be used here (see CSS Selectors on MDN Web Docs for a simple reference page).
Type Tab
General group:
Font: Select the font used to display text. See also: Fonts. This is equivalent to the CSS
font-familyproperty. -
Size: Enter the size in a measure, named size or percentage. This is equivalent to the CSS
font-sizeproperty. -
Color: This is the color of the text. Select a named font color as defined in the Edit Colors dialog (see Colors) or click the colored square to create a new color or to enter a color manually. The color value must be a valid HTML color name or hexadecimal color code. This is equivalent to the CSS
colorproperty. -
Background Color: This is the background color of the text. Select a named font color as defined in the Edit Colors dialog (see Colors) or click the colored square to create a new color or to manually enter a color value (a valid HTML color name or hexadecimal color code). This is equivalent to the CSS
background-colorproperty.
Spacing group:
Letter Spacing: Set the space between characters in a text in measure or percentage. This is equivalent to the CSS
letter-spacingproperty. -
Word Spacing: Set the space between each word in a text in measure or percentage. This is equivalent to the CSS
word-spacingproperty. -
Whitespace: Specify how to handle white spaces inside of an element. See CSS White-Space for details. This is equivalent to the CSS
white-spaceproperty.
Style group: Check any option to apply the selected style to text within the element. This list shows the CSS property and value for each of the options.
Bold: Sets the
font-weightto700. -
Italic: Sets
font-styletoitalic. -
Underline: Sets
text-decorationtounderline. -
Strikethrough: Sets
text-decorationtoline-through. -
Subscript: Sets
vertical-aligntosuper. -
Superscript: Sets
vertical-aligntosub. -
Capitalize: Sets
text-transformtocapitalize. -
Uppercase: Sets
text-transformtouppercase. -
Lowercase: Sets
text-transformtolowercase. -
Small-caps: Sets
font-varianttosmall-caps.
Formats Tab
General group:
Line-height: Specify the height of each line in the element's text, in measure or percentage. Note that this is not spacing between lines, but rather the complete height of the line itself including the text. Equivalent to the
line-heightproperty. -
Align: Select how text should be aligned, such as
left,center,rightorjustify. Equivalent to thealignproperty. -
First Indent: Specify the indentation of the first line of each paragraph in the element. Equivalent to the
text-indentproperty. -
Display: Select how to display the element. This can also be used to hide an element completely using the
noneoption. See CSS Display. Equivalent to thedisplayproperty.
Breaks group:
Before: Specifies whether a page break should occur before the element. Equivalent to the
page-break-beforeproperty. -
Inside: Specifies whether to accept page breaks within the element. Equivalent to the
page-break-insideproperty. -
After: Specifies whether a page break should occur after the element. Equivalent to the
page-break-afterproperty. -
Widows: Specifies how to handle widows within a paragraph (lines appearing alone on the next page if the paragraph does not fit on the current one). Equivalent to the
widowsproperty. Widows and orphans are ignored if thepage-break-insideproperty is set toavoid. -
Orphans: Specifies how to handle orphans within a paragraph (lines appearing alone at the end of a page if the paragraph does not fit on the current one). Equivalent to the
orphansproperty.
Spacing Tab
See also: Spacing.
Padding group: Defines padding (spacing inside the element) in measure or percentage:
All sides: Check to set all padding to use the Top value. Equivalent to the
borderproperty. -
Top, Left, Bottom, Right: Set padding for each side. Equivalent to the
border-left,border-top,border-rightandborder-bottomproperties.
Margin group: Defines margins (spacing outside the element) in measure or percentage:
All sides: Check to set all margins to use the Top value. Equivalent to the
marginproperty. -
Top, Left, Bottom, Right: Set the margin for each side. Equivalent to the
Border Tab
See also: Border.
Same for all sides: Defines the border properties for all sides using the Top properties. Equivalent to the
borderproperty. -
Top, Left, Bottom, Right: Each group defines the following properties:
Width: Specify the thickness of the border. Equivalent to the
border-widthproperty. -
Style: Specify the style of the border such as
solid,dashedordotted. Equivalent to theborder-styleproperty. -
Color: Specify the color of the border. The color value must be a valid HTML color name (see standard colors, on MDN Web Docs), or a hexadecimal color code (see Hex Calculator). Equivalent to the
border-colorproperty.
The Advanced editor is used to manually input rules. Note that to use this dialog, basic knowledge of CSS rules is a pre-requisite, as no check is currently done to verify that properties and values are correct.
Property List: Lists all the currently available properties for the selector.
Property: The name of the property. This must correspond exactly to a known property (see CSS Reference). An autocompletion drop-down displays to show possible values when typing.
Value: The value for the given property. The values must be valid for that property, see the CSS Reference link above and check the property for valid values.
New: Click to create a new line and type in the property.
Delete: Click to delete the currently selected property in the Property List.
Move Up: Move the currently selected property in the Property List up one position in the list.
Move Down: Move the currently selected property in the Property List down one position in the list.
