Preflight Results and Messages
Messages pane
The Messages pane is shared between the DataMapper and Designer modules and displays any warnings and errors from the data mapping configuration or template.
To open it in the Designer module, click the Messages button at the bottom right of the window (see Designer User Interface).
Buttons
  • Export Log : Click to open a Save As dialog where the log file (.log) can be saved on disk.
  • Clear Log Viewer : Click to remove all entries in the log viewer.
  • Filters : Displays the Log Filter.
  • Activate on new events : Click to disable or enable the automatic display of this dialog when a new event is added to the pane.
Field headers
  • Message: The contents of the message, indicating the actual error.
  • Component: Whether the entry is a warning or an error.
  • Source: The source of the error. This indicates the name of the step as defined in its step properties.
  • Date: The date and time when the error occurred.
Preflight Results pane
The Preflight Results pane displays any notifications or errors related to the template, its scripts, its code or output generation. Double-click a script warning/error to open the script in the script editor. The relevant line will be highlighted.
See also: Testing scripts.
