Export Template Report wizard
The Export Template Report wizard is opened through the menu: File > Export report.
It contains the following options:
File Name: Enter the desired file name for the template report.
Format: Select PDF or XML.
Click Next to go to the next set of options:
Generate Thumbnails: The generated thumbnail images will be included in the PDF file. When exporting an XML report, the thumbnails will be saved in the same folder as the XML, in a subfolder named Thumbnails.
Sections (first page): Save the first page of each section as a thumbnail image.
Image resources: Save all image resources as thumbnail images.
PDF Options:
Standard: The standard PDF report contains a summary of the template with an overview of all the settings and resources that are used in the template: media, master pages, contexts, sections, images, scripts, runtime parameters, etc. The file properties are included as well (see File Properties dialog). The report has a standard layout.
Template: A template design with the desired layout and variable data. This .OL-TEMPLATE file has to be made in the Designer.
DataMapper: A data mapping configuration that provides the variable data. This .OL-datamapper file has to be made in the DataMapper module, using the standard XML template report as data sample.
Custom: To create a custom PDF report, you need two files:
