Runtime Parameter Options
This page appears as part of the Advanced Print Wizard and the Job Creation Presets Wizard.
The Runtime Parameter Options page allows you to add runtime parameters to the Job. These runtime parameters could be used in a number of ways. Such as in the following scenarios:
Filtering rules scenarios
A filter condition could be used to compare a date from the record against a date passed in as a runtime parameter.
For instance, the record could have a due date, with only documents due in two weeks time to be selected. Calculating the date "two weeks from today" could be done in Workflow, with this date then having to be passed as a parameter back to Connect when Job Creation is started.
Finishing rules scenarios
Similar to filtering, a finishing condition could use runtime parameters to compare against.
For example, consider if a copy of a print job has to be produced, in which the copies have to be stapled, while the original print run are without staples. A runtime parameter could be used during job creation to indicate if the Job Creation is working on the original or the copy.
Without runtime parameters, the same functionality would require two job presets. So this use case becomes important for relatively complex presets where duplicating the preset creates a maintenance issue.
External sorting scenarios
External sorting benefits considerably from runtime parameters.
Paths for storing temporary files can be controlled from Workflow, allowing them to be unique per Job Creation. This facilitates running multiple instances of the sorting command at the same time. For instance, Workflow's temporary folder for a process could be supplied.
Especially in case of postal sorting, there can be a need for parameters that vary per job, such as intended delivery date, tracking id, and more.
Metadata properties
The value for a metadata property could be supplied through a runtime parameter. These could be, for example, the production date, or the name of the current operator.
Page breakdown
Runtime Parameters can be added, edited, removed, duplicated or moved within the Runtime Parameter table via the buttons to the right of the table.
The Runtime Parameter options are:
Add: Click to open a new Runtime Parameter.
This launches the Add/Edit Runtime Parameter dialog. -
Edit: Click to edit the
currently selected entry. This launches the Add/Edit Runtime Parameter dialog.
Double clicking on an entry in the table has the same effect as this button. -
Delete: Click to delete
the currently selected entry or entries. -
Duplicate: Click to create
a duplicated copy of the entry. This creates a new entry that is exactly the same as the original, with a numeric increment added to the end of the name. -
Move Up / Move Down: Click to move the selected entry (or entries) up or down within the table.
Runtime Parameter Table: The table lists all the currently available runtime parameters.
It is split up into the following columns
Parameter: The name of the parameter.
Type: The parameter type.
Default Value: Displays the default parameter value.
Advanced Print Wizard and Output Creation Preset Wizard navigation options
Print button (Advanced Print Wizard only) or Finish button (Output Creation Preset Wizard only):
