Codabar
Codabar is one of the barcode types that can be added to a template.
Note that this type of barcode processes tilde characters (~) in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
Barcode properties
This topic lists the properties of the Codabar barcode. For the properties of other barcode types, see Barcode type and properties.
Module width
Start Char and Stop Char
Use the drop-down to select the start and stop character for the barcode, which defines the encoding mode. Available characters are A, B, C.
Scale
Add Checksum
When checked, PlanetPress Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Human Readable Message
When this option is checked, PlanetPress Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
