Code 11, Code 93, Industrial 2 of 5, Interleaved 2 of 5, Matrix 2 of 5
Code 11, Code 93, Industrial 2 of 5, Interleaved 2 of 5, and Matrix 2 of 5 are a few of the barcode types that can be added to a template.
Note that barcodes of these types process tilde characters (~) in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
Barcode properties
This topic lists the properties of the following barcode types :
Code 11
Code 93
Industrial 2 of 5
Interleaved 2 of 5
Matrix 2 of 5
For the properties of other barcode types, see Barcode type and properties.
Module width
Scale
Fit to box: The barcode is stretched to fit the parent box in both width and height.
Add Checksum
When checked, PlanetPress Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Human Readable Message
When this option is checked, PlanetPress Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
SVG: Vector format. This is usually of higher quality, but may take longer to generate and is not compatible with Email output.
PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster and will display properly in Email output.
