GS1 DataMatrix
GS1 DataMatrix is one of the types of barcodes that can be added to a template; see Barcode.
About GS1 DataMatrix barcode data
In order to create a GS1 DataMatrix barcode, the barcode data must meet the following requirements.
  • The barcode data must start with a leading FNC1 character. Either ~1 or ~d232.
  • The GS1 Application Identifiers (AI) must be used for all data.
    The function code ~1 must be used as field separator for variable length AI elements.
  • Only ASCII characters should be used.
Barcode properties
This topic lists the properties of the barcode type GS1 DataMatrix. For the properties of other barcode types, see Barcode type and properties.
Module width
Preferred format
Use the drop-down to select the size of the Data Matrix.
Scale
Add Checksum
When checked, PlanetPress Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Tilde processing
Note: The following tilde codes are supported in GS1 DataMatrix barcodes:
  • ~1 = FNC1 character (for GS1 DataMatrix barcodes)
  • ~2 = Structure Append
  • ~3 = Reader programming
  • ~5 = Macro5
  • ~6 = Macro6
  • ~7 = ECI expressions
Human Readable Message
When this option is checked, PlanetPress Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
