PDF417
PDF417 is one of the types of barcodes that can be added to a template; see Barcode.
Barcode properties
This topic lists the properties of the barcode type PDF417. For the properties of other barcode types, see Barcode type and properties.
Mode
Use the drop-down to set the compaction mode:
  • Binary: allows any byte value to be encoded
  • Text: allows all printable ASCII characters to be encoded (values from 32 to 126 and some additional control characters)
  • Numeric: a more efficient mode for encoding numeric data
Error Correction Level
Use the drop-down to select the built-in error correction method based on Reed-Solomon algorithms. The error correction level is adjustable between level 0 (just error detection) and level 8 (maximum error correction). Recommended error correction levels are between level 2 and 5, but the optimal value depends on the amount of data, printing quality of the PDF417 symbol and decoding capabilities of the scanner.
Nr. of Columns
The number of data columns can vary from 3 to 30.
Nr. of Rows
A PDF417 bar code can have anywhere from 3 to 90 rows.
Bar height
Defines the height of the bars for a single row measured in pixels drawn.
Compact
Check this option to use Compact PDF417 instead of the PDF417 barcode. This shortened form of the PDF417 barcode is useful where the space for the symbol is restricted.
Scale
  • Proportionally: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Tilde processing
Color
Output format
