Royal Mail 4-State (CBC)
Royal Mail 4-State (CBC) is one of the types of barcodes that can be added to a template; see Barcode.
In PlanetPress Connect versions prior to 2019.2 this barcode was called "Royal Mail 4 State (RM4SCC)".
Note that this type of barcode doesn't process tilde characters (~) in the data as special characters.
Barcode properties
This topic lists the properties of the barcode type Royal Mail 4-State (CBC). For the properties of other barcode types, see Barcode type and properties.
Height, width and spacing
  • Bar height: the height of the (shorter) bars.
  • Extended bar height: the total height of the extended bars.
  • Bar width: the width of the bars.
  • Spacing: the distance between the bars.
Scale
  • Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Add Checksum
When checked, PlanetPress Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Human Readable Message
When this option is checked, PlanetPress Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Color
Output format
