Bar Chart Properties dialog
The Bar Chart dialog appears when a Bar Chart object is right-clicked and the Chart... option is clicked. It determines how the Bar Chart is displayed in output and in Preview mode (see Business graphics).
All of the settings in this dialog are equivalent to a property in the amCharts library (see: amCharts' Class Reference). The description of each setting specifies the corresponding property. When you've made a setting, you can also find the property on the Source tab.
General tab
Most settings on the General tab correspond to properties of the AmSerialChart class in the amCharts library; see: AmSerialChart.
General Group:
Display grid above graph: Check to display the grid on top of the bars so that it is always visible.
(Equivalent to thegridAboveGraphsproperty; see: gridAboveGraphs.) - Rotate: Check to rotate the chart 90 degrees so that the bars are horizontal starting from the left.
(Equivalent to therotateproperty; see: rotate.) -
Stack Series: Check to stack the values in one bar, instead of having one bar per value.
(Equivalent to thestackTypeproperty of theValueAxis; see: stackType.)
Text Group: Determines how text is displayed in labels and legends.
Font: Enter the font-face to use to display text. The font must be installed on the system and defaults to Verdana if the font is not found.
(Equivalent to thefontFamilyproperty; see: fontFamily.) -
Size: Enter the size of the font. Defaults to 11.
(Equivalent to thefontSizeproperty; see: fontSize.) -
Color: Select the color in which to display text: click the colored square to open the Color Picker dialog (Color Picker), or enter a hexademical color code (see Hex Calculator) or a predefined CSS color (see MDN Web Docs - named color).
(Equivalent to thecolorproperty; see: color.)
3D Group: Creates a 3D effect if both settings in this group are higher than 0.
Value Axis tab
Settings on the Value Axis tab are equivalent to properties of the ValueAxis class in the amCharts library; see: ValueAxis.
Title group:
Label: Enter a label for the value axis (the Y axis, or the X axis if the graph is rotated).
(Equivalent to thetitleproperty; see: title.) -
Bold: Check this option if the title should be bold.
(Equivalent to thetitleBoldproperty; see: titleBold.) -
Color: The default label color is black. To select a custom color for the label, click the colored square to open the Color Picker dialog (Color Picker), or enter a hexademical color code (see Hex Calculator) or a predefined CSS color (see MDN Web Docs - named color).
(Equivalent to thetitleColorproperty; see: titleColor.) -
Font Size: Enter a font size for the label.
(Equivalent to thetitleFontSizeproperty; see: titleFontSize.)
Grid group:
Color: Select a color for the grid lines that divide the value axis: click the colored square to open the Color Picker dialog (Color Picker), or enter a hexademical color code (see Hex Calculator) or a predefined CSS color (see MDN Web Docs - named color).
(Equivalent to thegridColorproperty; see: gridColor.) -
Opacity: Enter the opacity percentage of the grid. Default is 15%. 100 is fully opaque, 0 is transparent.
(Equivalent to thegridAlphaproperty; see: gridAlpha.) -
Thickness: Enter a thickness for the grid lines. Default is 1.
(Equivalent to thegridThicknessproperty; see: gridThickness.) -
Tick Length: Length of the tick marks.
(Equivalent to thetickLengthproperty; see: tickLength.)
Axis group:
Color: Select a color for the value axis: click the colored square to open the Color Picker dialog (Color Picker), or enter a hexademical color code (see Hex Calculator) or a predefined CSS color (see MDN Web Docs - named color).
(Equivalent to theaxisColorproperty; see: axisColor.) -
Opacity: Enter the opacity in percentage for the axis. 100 is fully opaque, 0 is transparent. Set opacity to 0 to hide the axis.
(Equivalent to theaxisAlphaproperty of theValueAxis; see: axisAlpha.) -
Thickness: Enter the thickness of the axis.
(Equivalent to theaxisThicknessproperty of theValueAxis; see: axisThickness.)
Labels: Check this option to make the labels on the value axis visible. This is often useful in rotated charts.
(Equivalent to thelabelsEnabledproperty of theValueAxis; see: labelsEnabled.)-
Frequency: Defines per how many grid lines a label will be placed.
(Equivalent to thelabelFrequencyproperty of theValueAxis; see: labelFrequency.)
Category Axis tab
Settings on the Category Axis tab correspond to properties of the CategoryAxis class in the amCharts library; see: CategoryAxis.
Title group:
Label: Enter a label for the category axis (the X axis, or the Y axis if the graph is rotated).
Bold: Check if you want the title to be bold.
Color: Select a custom color for the label (default is black): click the colored square to open the Color Picker dialog (Color Picker), or enter a hexademical color code (see Hex Calculator) or a predefined CSS color (see MDN Web Docs - named color).
Font Size: Enter a font size for the title.
Grid group:
Color: Select a color for the grid lines that divide the category axis: click the colored square to open the Color Picker dialog (Color Picker), or enter a hexademical color code (see Hex Calculator) or a predefined CSS color (see MDN Web Docs - named color).
Position: Specifies if a grid line is placed on the centre of a cell or on the beginning of a cell.
(Equivalent to thegridPositionproperty; see: gridPosition.)Tip:
The position of the ticks (which is Middle by default) does not move with the grid.
To change the tick position, add the following to thecategoryAxissection on the Source tab:"tickPosition": "start". -
(Equivalent to thetickLengthproperty; see: tickLength.)Tip:
By default, one label per grid line will appear on the Category axis.
To change that frequency, add the following to thecategoryAxissection on the Source tab:"labelFrequency": "2"(replace 2 by the desired number of grid lines).
Axis group:
(Equivalent to theaxisAlphaproperty; see: axisAlpha.) -
(Equivalent to theaxisThicknessproperty; see: axisThickness.) -
Auto Wrap: Specifies if axis labels (when horizontal) should be wrapped if they don't fit in the allocated space.
(Equivalent to theautoWrapproperty; see: autoWrap.)
Graphs tab
Most settings on the Graphs tab correspond to properties of the AmGraph class in the amCharts library; see: AmGraph.
Labels:
Text: Text of the data labels. You can use tags like [[value]], [[description]], [[percents]], or[[category]]. (Equivalent to the
labelTextproperty; see: labelText.)
Position: Position of the data labels. Possible values are: "bottom", "top", "right", "left", "inside", "middle". (Equivalent to the
labelPositionproperty; see: labelPosition.)
Rotation: Rotation of the data labels. Supported notations:
0.0,
0.0°or
0.0 deg. (Equivalent to the
labelRotationproperty; see: labelRotation.)
Offset: Vertical offset of the data labels. A positive offset moves the data labels up. A negative value moves them down. (Equivalent to the
labelOffsetproperty; see: labelOffset.)
Anchor: Select whether the start, middle or end of a data label should be anchored to the bar. This setting moves the labels horizontally. (Equivalent to the
labelAnchorproperty; see: labelAnchor.)
Columns:
Width: Specify a bar width between 0 and 1. (This is a relative width, not pixel width). (Equivalent to the
columnWidthproperty; see: columnWidth.)
Spacing: The gap in pixels between two columns of the same category. (Equivalent to the
columnSpacingproperty of the
AmSerialChartclass; see: columnSpacing.)
Legend tab
Settings on the Legend tab correspond to properties of the AmLegend class in the amCharts library; see: AmLegend.
Show Legend: Specifies if legend is enabled or not.
(Equivalent to theenabledproperty; see: enabled.) -
Legend Group: Defines how the legends are shown.
Equal label widths: Check so that all labels are of equal width in the Legends box. The Legend's width will accommodate the largest value.
(Equivalent to theequalWidthsproperty; see: equalWidths.) -
Position: Use the drop-down to select where the legend is shown: at the Right, Left, Top or Bottom.
(Equivalent to thepositionproperty; see: position.) -
Align: Use the drop-down to select how to align the text in the labels: Left, Middle or Right.
(Equivalent to thealignproperty; see: align.) -
Horizontal Space: Horizontal space between legend items, in pixels.
(Equivalent to thespacingproperty; see: spacing.) -
Vertical Space: Enter a numerical value (in pixels) to define the vertical space between legend items, and also between the legend border and the first and last legend item.
(Equivalent to theverticalGapproperty; see: verticalGap.) -
Max Columns: Enter a numerical value to define the maximum number of columns in the legend. If the Legend's position is set to "right" or "left", this is automatically set to 1.
(Equivalent to themaxColumnsproperty; see: maxColumns.)
Labels Group: Defines if and how labels are shown in the Legend.
Text: Enter the text used to display the labels;
[[title]]is a variable that will be replaced with the title of the graph.
(Equivalent to thelabelTextproperty; see: labelText.)
Markers Group: Defines how the Legend's Markers look. Markers are icons with a color matching the Legend with its corresponding line.
Type: Use the drop-down to select in which shape the Markers are displayed; "none" hides the Markers completely.
(Equivalent to themarkerTypeproperty; see: markerType.) -
Size: Enter the size (in pixels) for the Markers to be displayed.
(Equivalent to themarkerSizeproperty; see: markerSize.) -
Label Gap: Enter the distance (in pixels) between the legend marker and legend text.
(Equivalent to themarkerLabelGapproperty; see: markerLabelGap.) -
Border Width: Use the drop-down to define the thickness of the border added to the Markers. The default value (0) means the line will be a "hairline" (1 px). In case the Marker type is line, this style will be used for the line thickness.
(Equivalent to themarkerBorderThicknessproperty; see: markerBorderThickness.) -
Border Color: Color of the Legend's border. Enter a hexademical color code (see Hex Calculator) or a predefined CSS color (see MDN Web Docs - named color), or click the colored square to open the Color Picker dialog (Color Picker).
(Equivalent to themarkerBorderColorproperty; see: markerBorderColor.) -
Border Opacity: Enter a numerical value between 0 and 100 to define the opacity (in percentage) of the border.
(Equivalent to themarkerBorderAlphaproperty; see: markerBorderAlpha. When specified on the Source tab, the value should be between 0 and 1, e.g. 0.8.)
Source tab
The JSON on the Source tab reflects the choices made in the other tabs and, more importantly, provides the possibility to add in any amCharts configuration option that is unavailable via the other tab menus. For more information see: Adding and editing properties manually.
