Serving a Web Page - Sample Project
The Serving a Web Page Sample Project generates a Connect solution that can serve a web page.
To start the Sample Project, select File > New > Sample Projects > Serving a Web Page from the menu.
For more detailed information about this project, and instructions on how to test and customize it, see Sample Project: Serving a Web Page.
The wizard contains the following options.
- Workflow
- Project folder: Select a folder. In this folder, the Project Wizard will create two folders: Configurations and Workspace. The project's resource files are saved to the Configurations folder. The Workspace folder is meant to be used when debugging the solution (see Serving a Web Page - Sample Project).
- Send Templates and resources to Workflow: Check this option to send the necessary resource files to the active Workflow instance on the local machine. Without these files the Workflow configuration can be inspected, but it cannot be tested; in order to test the configuration, you'll have to send the resources manually (see Sending files to Workflow).
Note: In order for this option to work, Workflow and the Designer must be installed on the same machine. In addition, the PPMessenger service must be running. By default, this service is always started automatically from the moment Workflow has been installed.
