Information about OL ConnectWorkflow
If you wish to use OL Connect
Workflow (automation),
you will need to install OL Connect Workflow 2023.2 as well. Workflow 2023.2 is provided through a separate
installer which is available on CD or for download as follows:
- If you are a Customer, the installer can be downloaded from the Upland Objectif Lune Connect Web Activations page: http://www.objectiflune.com/activations
- If you are a Reseller, the installer can be downloaded from the Upland Objectif Lune Connect Partner Portal: http://extranet.objectiflune.com/
OL Connect Workflow can
be installed in parallel on the same machine as an existing PlanetPress®
Suite 7.x installation.
Note however:
- If both versions need to be hosted on the same machine, OL Connect Workflow 2023.2 must always be installed after the legacy PlanetPress® Suite 7.x installation.
- When uninstalling OL Connect Workflow 2023.2, you may be prompted to repair your legacy PlanetPress® Suite 7.x installation.
- If OL Connect Workflow
2023.2 has been installed alongside PlanetPress® Suite 7, Capture can no
longer be used with Workflow 7.
The plugins are now registered uniquely to Workflow 2023.2 and the messenger for Workflow 7 is taken offline. It is only then possible to use Capture from OL Connect Workflow 2023.2. - OL Connect Workflow 2023.2 and PlanetPress® Suite Workflow 7 cannot run simultaneously, since only one version of the Messenger service can run at a time. In fact, no two versions of Workflow can be run simultaneously on the same machine, regardless of versions.
- It is possible to switch between different versions running by shutting down one version's services and then starting the other. However, this is not recommended. There are no technical limitations that prevent processes from previous PlanetPress Suite Workflow versions (as far back as Version 4) to run on OL Connect Workflow 2023.2, removing the need to run both versions.
For more information on the licensing of Workflow 2023.2, please see Activating a License.
