PlanetPress Workflow Button
The PlanetPress Workflow button provides access to the File menu options.
Options
  • New: Closes the configuration that is currently opened and creates a new configuration, with a single example process and no printer queues. See Creating a new configuration.
  • Open: Displays the dialog to open an existing configuration file.
  • Save: Saves the current configuration. If the file is new and has not yet been saved, or if the configuration is the loaded directly from the service, the Save As dialog is displayed instead. See Saving and sending a Workflow Configuration.
  • Save As: Saves the current configuration under a new name. It does not overwrite any existing configuration file, unless an existing file is selected and overwritten manually by the user.
  • Import:
    • Configuration Components: Displays the Import Processes dialog, letting you import processes and other components from other existing configuration files. See Importing processes.
    • PlanetPress Document: Displays the dialog to import a PlanetPress Connect Document to be added to the list in the components area.
    • PrintShop Mail Document: Displays the dialog to import a PrintShop Mail Document to be added to the list in the components area.
    • Connect Content: Displays the dialog to import Connect files including templates, data mapping configurations, presets and packages.
  • Send Configuration: Sends the current configuration to the PlanetPress Watch service. See Saving and sending a Workflow Configuration.
  • Close: Closes the configuration that is currently opened and creates a new configuration, with a single example process and no printer queues. Closing the current configuration is the same as creating a new one.
  • Recent Documents: Displays a list of the 9 most recently opened configuration files. Click on any of them to open it.
  • Select Language: Click to display the language selection dialog, which changes PlanetPress Workflow interface language. See Change the Interface language.
  • Preferences: Displays the Options dialog. See Preferences.
  • Exit: Closes PlanetPress Workflow. See Exit PlanetPress Workflow Configuration program.
When using the New, Open, Close, Recent Documents and Exit menu options, if your current configuration has not been saved after modifications, a dialog will open asking if you want to save, not save, or cancel the action and return to the current configuration.
