M-Files
M-Files is an Enterprise Content Management (ECM) system that is widely used in industry. It provides a metadata driven mechanism for storing, versioning and sharing files across an organization. See https://www.m-files.com for more detail about M-Files.
The Workflow M-Files solution is based on two plugins:
These plugins are not initially installed with Workflow. available for download on the OL Resource Center. After downloading the .PPK files, you will then need to import them into Workflow yourself.
See Importing a plugin.
Once installed, the M-Files plugins will appear in the Document Management category in the Plug-In Bar.
Note: To be able to use this plugin you need a working M-Files installation and a user account with appropriate permissions.
Plugin legal notices and acknowledgments
Copyright © 2019 Objectif Lune Incorporated. All rights reserved.
