Add/Remove Text
Add/Remove Text action tasks can be used to perform the following actions on the data file they receive:
  • Add or remove characters.
  • Add or remove lines of data.
  • Add the content of a text file.
Note that the content must be located at the beginning or the end of the data file.
Any text-based file can be used in this task, even formats that are not directly compatible with PlanetPress. As long as the text is visible in a text-based editor (such as Notepad), it is readable and supported by this task.
The selected operation (adding or removing lines, text or pages) is made on the data file.
The modified data file is output from this task. Metadata is not modified in any way if it is present.
General tab
  • Action group
    • Add: Select if you want the task to add content to the job file.
    • Remove: Select if you want the task to remove content from the job file.
  • Content: Select what the task will actually add or remove. Select Text file to add the whole content of a text file to the beginning or end of the job file. Select Characters to add the string of characters entered in the Characters box to the beginning or end of the job file, or to remove a given number of characters from the beginning or end of the job file. Select Lines to add the lines of text entered in the Lines box to the beginning or end of the job file, or to remove a given number of lines from the beginning or end of the job file.
  • Position: Select whether you want the task to add or remove content from the beginning or end of the job file.
  • Add CRLF after last line: Select if you want to add a CRLF (carriage return/line feed) character after the last line of text added to the job file. This option is only available when you choose to add lines of text to the job file.
  • ASCII file: Enter the path and name of the text file to be added to the job file, or use the Browse button to navigate to this file. This box is only displayed when the Text file option is selected in the Content box.
  • Characters: Enter the string of characters to be added to the job file. This box is only displayed when the Characters option is selected in the Content box.
  • Lines: Enter the lines of text to be added to the job file. This box is only displayed when the Lines option is selected in the Content box.
  • Remove: Enter the number of characters or lines to be removed from the job file. This box is only displayed when Remove is selected in the Action group and when the Characters or Lines option is selected in the Content box.
