Capture-PGC splitter
The Capture-PGC splitter task can be used to separate each document into its own PGC file so they can be processed separately. The splitter then sends each document PGC to the next action, which should be the Capture-Fields processor task. Note that using the Capture-PGC splitter will cause your process to take more time, since each PGC must pass through the Capture-Fields processor and then the Capture-Get document task.
Note: Due to the fact that the Capture-PGC splitter task modifies the original PGC, in some cases the legality of the PGC signature may be compromised. This depends on your country or region's laws, so if your implementation of Capture requires signatures to be authenticated please consult a legal advisor for more details.
A PGC file received from an Anoto digital pen.
The PGC file is split by document, if a document can be matched for each pattern ID found in the PGC. The match is made by comparing each Pattern ID with the information found in the Capture database. If more than one pattern is used in a document (pattern on multiple pages of the document), all of the information for this document (more than one Pattern ID) is sent down as a split. Patterns that do not match any document are sent individually, one Pattern ID per split.
One or more PGC file, separated as described above.
General tab
- Pattern sequence group: Determines what Pattern Sequence will be assigned to each PGC file.
- Type: Specify from where the Pattern Sequence should be taken.
- None: Do not use a Pattern Sequence.
- Pen Information: Use the Pattern Sequence assigned to the pen in the PlanetPress Capture Database.
- Custom: Overwrite the pen's information and specify a Pattern Sequence manually or use a data selection.
- Custom Pattern Sequence: If you choose Custom in the Type drop-down, enter a manual Pattern Sequence or a data selection that contains the pattern sequence to be used.
"Anoto" and the Anoto logotype are trademarks owned by Anoto AB. PLANETPRESS CAPTURE is based on Anoto Digital Pen and Paper Technology, which is covered by over 200 patents worldwide, including but not limited to US6663008, US7172131, US7248250, US7281668, JP3872498, JP3842283, CN1595440, SE517445, RU2256225, and AU773011. |
