Metadata Sorter
The Metadata Sorter action task allows Metadata to be sorted sequentially on three different levels, alphabetically or numerically. It also allows sorting in ascending and descending order.
For more information about Metadata see Metadata.
Any data file with accompanying Metadata.
The order of the Metadata is changed in accordance with the rules set forth in the task's properties.
The Metadata Sorter task works on all nodes, regardless of their selected state.
The original data file is output, along with the modified Metadata.
- Group: Sorts the Metadata by group.
- Document: Sorts the Metadata by document.
- Data page: Sorts the Metadata by data page.
For each parameter, three columns are available: Sort By, Then by, Then by (again). This lets you sort your document level in three different orders sequentially. Sorts are always done from left to right, top to bottom, giving you a total of 9 sorting possibilities.
When you click on either of the sort boxes, a small pop-up displays the following options:
- Sort by: The drop down displays a list of available fields and attributes in that level, letting you select on which to sort. The field or attributes must be present for every instance of the level you are searching on, or the task raises an error.
- Order: Choose Ascending (orders like a,b,c, or 1,2,3) or Descending (orders like 3,2,1 or c,b,a) order. If the Numeric sorting option is not checked, numbers are sorted like this: "1, 10, 11, 12, 2, 3, 4, 5, 6, 7, 8, 9".
- Numeric Sorting: Check to sort numerically instead of alphabetically (only supports whole numbers. Currency with thousands separator and decimal points will not work). If any non-numeric value is found in the field or attribute, in any instance of the level, the task raises an error.
