Update Data Records
The Update Data Records action task updates records in the OL Connect Database using values from the current Metadata or from JSON.
Each of the OL Connect Content Creation tasks can do the same, if the Update Records from Metadata option is enabled for that task.
The Update Data Records task can be useful when data needs to be updated multiple times before actually generating content, for instance when Postal Address Cleansing and Sorting is a two-pass process.
The current Job File is not used by this task. In order to update values in the Connect database, the task requires that the current Metadata contains record IDs, or that the given JSON contains a JSON Record Data List (see: Types of JSON in Workflow and ).
The records, of which the IDs are found in the source data, are updated either from the Metadata or from JSON.
Note: Date strings conforming to ISO 8601 are parsed and stored in the OL Connect database as Unix timestamps, i.e. the total number of seconds from the starting time of UTC (Universal Time, Coordinated) to the current time (with zero time zone offset). For instance: 1675950179.
The Job File is not changed by this task.
  • Update Source: Select the data source from which the records in the Connect database will be updated.
OL Connect Proxy Tab
This tab is common to all OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
  • OL Connect Proxy Address: Enter the machine name or IP Address where the OL Connect Server resides.
  • Port: Enter the port to use to communicate with the OL Connect Server. Default: 9340
  • User name: Enter the user name expected by the OL Connect Server.
  • Password: Enter the password expected by the OL Connect Server for the above user name.
