Search and Replace
Search and Replace Action tasks are used to locate and replace strings of data within the job file and to replace them with other strings of data. Note that this Action task cannot be used with binary files.
For more advanced search and replace functionality, see Advanced Search and Replace.
Any text-based file can be used in this task, even formats that are not directly compatible with PlanetPress. As long as the text is visible in a text-based editor (such as Notepad), it is readable and supported by this task.
The appropriate changes are made to the data file (replacing text).
The modified data file is output from this task. Metadata is not modified in any way if it is present.
- Find: Enter the string of data for which to search. You can use any combination of text, variables and data selections; see Variable task properties.
- Replace with: Enter the string of data to use as a replacement. Since this is also a variable property box, the same as above applies.
- List of words to find and replace: Lists each string to find, and its replacement. These are executed in order, from top to bottom.
- Find: Enter the string of data for which to search. In this variable property box, you may enter static characters, variables, job information elements, data selections, or any combination of these.
button: Click to add a new line to the list of words to find and replace.
button: Click to remove the currently selected line from the list.
button: Move the currently selected line up one position.
button: Move the currently selected line down one position.
