Send to Folder
Send to Folder Action tasks send the files they receive to a local folder. They perform the same function as Send to Folder Output tasks, with the only difference being that in this case PlanetPress Workflow will wait for the task to be completed before going on to the next task in the configuration.
Note: As with any task that can refer to network resources, it is important to understand the considerations involved with paths and permissions of these resources. Please refer to the Network considerations page.
Any data file in any format.
A copy of the data file is saved on the hard drive at the specified location.
The original data file, Metadata and Job Info variables are not modified, they are passed on to the next task.
- Folder: Enter the path of the folder to which the files are to be saved.
- File name: Enter the name of the output files generated by this task. To prevent each new file from overwriting the previous one, you should use variable names. You can use any combination of text, variables and data selections; see Variable task properties.
- Concatenate files: If this option is selected, when PlanetPress Workflow tries to save a file under a given name, if a file under that same name already exists, instead of overwriting it, PlanetPress Workflow will append the content of the new file to that of the existing file. This appending process will go on until the file is removed from the folder.
- Separator string: This option is used to add a separator string between the content of each file when the Concatenate files option is selected.
