Extract ICR Data
The Extract ICR Data task retrieves the ICR data from the specified document ID from the Capture Database and adds this information to the current Metadata in the process, at the specified level.
Any data file, but generally one associated with the document in question (either a PGC or a PDF), along with an associated Metadata file.
A query is made to the Capture database and the ICR data is retrieved. The document that is queried must be available in the database (must not have been closed and retrieved previously).
The original data file is output by this task, along with the original Metadata file that has been enhanced with the ICR data at the selected level.
  • Document ID: A variable data field that corresponds to the database ID of the document from which you want to retrieve ICR data. The Document ID is generated by the system through the Capture Fields Generator. The ID must correspond to a document in the Capture database, or the task will fail with an error.
  • Metadata Level: A drop-down list containing all of the levels of Metadata. Choose the one where the ICR data will be added.
