File Count
File Count tasks check if a target folder contains a specified number of files. They can be used as Condition task or as Input task.
When used as Input task, the task triggers the process to run only when the condition is true. As long as the condition is false, it does nothing (except log any errors).
Setting the file count to 0 allows to take action, for example, when a scheduled process is expected to have files but it doesn't.
At run time, the number of files in the folder is compared to the specified value, using the specified operator.
If the folder or file count value is invalid and the task is used as Input task, the process does not run. If it is a Condition task, it returns False. No error is generated.
Job Information definitions
When used as Input task, the File Count task sets the following Job Info variables.
  • %1 - FolderName. The target folder.
  • %2 - Mask. The specified mask.
  • %3 - FileCount: The specified file count.
  • Target folder: Enter the full path of the folder from which the input files are to be taken, or use the Browse button to select it. Note that subfolders are not processed.
    This is a variable property field. You can use any combination of text, variables and data selections; see Variable task properties.
  • Masks: Enter a single or multiple file names or use file name masks (see Masks). Multiple filters are separated by a semicolon (e.g. *.csv;.xls*).
    This is a variable property field. (See Variable task properties.)
    • Treat as regular expressions: When ticked, the contents of the Mask field are deemed to be a regular expression . You can specify multiple masks based on regular expressions, separating the regular expressions by a semicolon.
      Please refer to Regular Expressions for more information.
    Note: No Variable Data can be used inside this field if the Treat as regular expressions option is ticked. The percent sign, the curly brackets and the period are all key elements of the RegEx syntax, therefore they cannot be mixed and matched with Workflow variable data syntax (e.g. %1, ${global.myvar}, etc.). Also, there is no validation of the RegEx being specified.
  • File count: Select whether the condition is to check if the file count is equal to, less than, greater than, less than or equal to, or greater than or equal to the specified value.
  • Value: Enter the desired file count. This is a variable property field. (See Variable task properties.)
Advanced properties
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PlanetPress Workflow Tools working folders under the "Backup" folder.
