SMTP Input
SMTP Input tasks are used to receive SMTP requests made by any email client or other SMTP commands and can act as an SMTP proxy, processing emails before they are sent to another SMTP server. In order for this task to receive files, the SMTP Server (also called "Outgoing Email Server") in the email client must point to Connect Workflow server's IP or hostname.
Secure communication for the SMTP Server is enabled and configured in the preferences for the SMTP Input. See SMTP Input preferences.
Caution: Emails received through this task will not reach their intended destination if the process does not end with a Send Email Output Task, or contain the PlanetPress Connect Create Email Content task.
Example
In this example, the SMTP Input plugin is used to capture incoming emails data that must meet certain conditions as the subject that contains "Work to do" and the sender that contains "client@company.com ". The process then redirects the content of those emails to an extraction and finally to a PDF printing.
The SMTP Input task does not, by itself, capture any files. Neither does it directly wait for requests to be received. Actually, it is the SMTP Server service that receives the requests and places them in a specific location on the drive.
When a request is received, the SMTP Input polls that location and finds the requests and all attachments. It will always pick up the "oldest" request received.
Caution: Due to a technical limitation the SMTP Input task does NOT receive the BCC addresses from most emails sent to it.
The task reads the incoming SMTP request and provides the data within its body.
Depending on the Data Location option, the output is different:
  • Envelope: The request file in XML format, including all email fields (from, to, cc, bcc, subject, body) as well as additional header fields (email client information, attachments, etc). The message body and attachments are available through specific XML attributes. These files do not have the full path, but you can use the %t%O variable to get the current temporary folder where they are located.
    Tip: Suppose we have two files named in the XML file under /ppemail[1]/@rawemail and /ppemail[1]/body[1]/@html respectively.
    With
    %t%O\xmlget('/ppemail[1]/body[1]/@html',Value,KeepCase,NoTrim)
    and
    %t%O\xmlget('/ppemail[1]/@rawemail',Value,KeepCase,NoTrim)
    we get both the body and the whole raw email.
  • Attachments: The input task loops through each attachment and sends them down through the process. While the Envelope is not available, the Job Infos contain pretty much all of the information you would get from it.
  • Data location: Determines what files are sent into the process:
    • Envelope: Only the request envelope is sent to the process (see above).
    • Attachments: Each attachment is sent down the process (see above).
  • Unzip attached file: Select to unzip the attached files.
    • Zip password: Enter the password required to unzip the attached files (if any). Note that you can use variables and data selections.
  • Conditions: Defines a filter on capturing files from the SMTP Service's hot folder. When a condition is added, only files that match this filter are captured, the rest remain untouched.
    • “Subject” contains: Select to limit those messages used by this task to those with a specific subject. The subject you enter in the box below can include variables and wildcards.
      • Nothing: Select to limit those messages used by this task to those that do not specify any subject.
    • “From” contains: Select to limit those messages used by this task to those that are sent from a specific address. The address you enter in the box below can include variables and wildcards.
    • “To” contains: Select to limit those messages used by this task to those that are sent to a specific address. The address you enter in the box below can include variables and wildcards.
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PlanetPress Workflow Tools working folders under the "Backup" folder.
