| JSON StructuresThe PReS Connect REST API uses various JSON structures to describe certain inputs and outputs to resource methods. These structures can be broken down into the following categories:
                                            Common - Structures that are commonly used throughout the REST APISpecific - Structures that are used by a specific resource method or service in the REST API Common StructuresCommon JSON structures used in the PReS Connect REST API include the following: JSON IdentifierDescribes an identifier for a single data entity or managed file in PReS Connect. The structure consists of an objectwith a single name/value pair: Example:{
    "identifier": 12345
 JSON Identifier (Named)Describes a named identifier for a single managed file in PReS Connect. The structure consists of an objectwith a single name/value pair: Example:{
    "identifier": "Promo-EN-1000.csv"
 JSON Identifier ListDescribes a list of identifiers for multiple data entities in PReS Connect. The structure consists of an objectwith a single name/value pair: Example:{
    "identifiers": [ 12345, 23456, 34567 ]
 JSON Name/Value List (Properties Only)Describes a list of properties (each as a name/value pair). The structure consists of an arrayofobjectseach with the following name/value pairs: Example:[
        "name": "start",
        "value": "2015-01-01 00:00:00T-0500"
        "name": "end",
        "value": "2015-12-31 23:59:59T-0500"
 JSON Name/Value ListDescribes a list of properties (each as a name/value pair) for a data entity of a specific ID. The structure consists of an objectwith the following name/value pairs:
                                                id- the data entity identifier (type ofnumber)
                                                properties- the data entity properties, consisting of anarrayofobjectseach with the following name/value pairs:
 Example:{
    "id": 12345,
    "properties": [
            "name": "start",
            "name": "end",
 JSON Name/Value ListsDescribes multiple lists of properties (as name/value pairs) for data entities of a specific ID. The structure consists of an arrayof JSON Name/Value List structureobjects. Example:[
        "id": 12345,
        "properties": [
                "name": "start",
                "name": "end",
        "id": 23456,
        "properties": [
                "name": "start",
                "name": "end",
 Specific StructuresSpecific JSON structures used in the PReS Connect REST API include the following: JSON Identifier (with createOnly flag)Describes an identifier for a single job set entity, along with additional parameters used specifically in an output creation operation. The structure consists of an objectwith the following name/value pairs: Example:{
    "identifier": 12345,
    "createOnly": true
 JSON Identifier List (with createOnly flag)Describes a list of identifiers for multiple job entities, along with additional parameters used specifically in an output creation operation. The structure consists of an objectwith the following name/value pairs: Example:{
    "identifiers": [ 12345, 23456, 34567 ],
    "createOnly": true
 JSON Record Content ListDescribes a list of data fields (as name/value pairs), nested data records (if any), along with a number of additional properties for a data record  entity of a specific ID.
                                            A data record entity (in the recorddata table) can contain one or more data tables that each contain one or more data record entities (nested data record entities). A nested data record entity can itself contain one or more data tables that each contain one or more nested data record entities, and so on for potentially multiple levels of nested data tables and data record entities.  A data record entity that contains a data table of nested data record entities is considered to be the parent of the data record entities contained in that data table (which are considered to be the children). See the Data Entities page of the Technical Overview section for further detail on data set and data record entities. The structure consists of an objectwith the following name/value pairs:
                                                id- the data record entity identifier (type ofnumber)
                                                fields- a list of data fields in the data record entity, consisting of anarrayofobjectseach with the following name/value pairs:
                                                records- a list of any nested data record entities, consisting of anarrayofobjectseach with the following name/value pairs:
                                                    table- the data record entity data table name (type ofstring)
                                                    parentrecordid- the data record entity identifier of parent entity (type ofnumber)
 Specific to data record entities that are children of a data set entity (data record entities in the recorddata table), two additional name/value pairs are included: Specific to nested data record entities that are children of a data record entity, two additional name/value pairs are included: Examples:{
    "id": 12345,
    "table": "record",
    "datasetid": 34567,
    "fields":[
            "name": "ID",
            "value": "CU00048376"
            "name": "Gender",
            "value": "M."
            "name": "FirstName",
            "value": "Benjamin"
            "name": "LastName",
            "value": "Verret"
    "id": 45678,
    "table": "detail",
    "parentrecordid": 23456,
    "fields": [
            "name": "ItemNumber",
            "value": "PSM002"
            "name": "ItemDesc",
            "value": "PSM Production (unlimited)"
            "name": "ItemUnitPrice",
            "value": "495.00"
            "name": "ItemOrdered",
            "value": "2"
            "name": "ItemTotal",
            "value": "990.00"
    "id": 23456,
    "table": "record",
    "datasetid": 12345,
    "fields": [
            "name": "ID",
            "name": "Date",
            "value": "2012-03-29T13:00Z"
            "name": "DueDate",
            "value": "2012-04-28T14:00Z"
            "name": "InvNumber",
            "value": "INV9441991"
            "name": "Gender",
            "value": "M."
            "value": "Benjamin"
            "name": "LastName",
            "value": "Verret"
            "name": "TotalOrdered",
            "value": "3"
            "name": "InvSubTotal",
            "value": "1485.00"
            "name": "InvTaxTotal",
            "value": "111.38"
            "name": "InvTotal",
            "value": "1596.38"
    "records": [
            "id": 45678,
            "table": "detail",
            "fields": [
                    "value": "PSM002"
                    "name": "ItemDesc",
                    "value": "495.00"
                    "value": "2"
                    "value": "990.00"
            "id": 45679,
            "table": "detail",
            "fields": [
                    "value": "PSM005"
                    "name": "ItemDesc",
                    "value": "Upgrade (Starter to Web)"
                    "value": "495.00"
                    "value": "1"
                    "value": "495.00"
 JSON Record Content ListsDescribes multiple lists of data field values (as name/value pairs), nested data records (if any), along with a number of additional properties for data record entities of a specific ID. The structure consists of an arrayof JSON Record Content List structureobjects. Example:[
        "id": 45678,
        "table": "detail",
        "fields": [
                "value": "PSM002"
                "name": "ItemDesc",
                "value": "495.00"
                "value": "2"
                "value": "990.00"
        "id": 45679,
        "table": "detail",
        "fields": [
                "value": "PSM005"
                "name": "ItemDesc",
                "value": "495.00"
                "value": "1"
                "value": "495.00"
 JSON Record Content List (Fields Only)Describes a list of data field values (as name/value pairs) for a data record, used to update an existing data record entity of a specific ID. The structure consists of an objectwith the following name/value pairs:
 Example:{
    "id": 12345,
    "fields": [
            "value": "Benjamin"
            "name": "LastName",
            "value": "Verret"
 JSON Record Content Lists (Fields Only)Describes multiple lists of data field values (as name/value pairs) for a data record,  used to update existing data record entities of a specific ID. The structure consists of an arrayof JSON Record Content List (Fields Only) structureobjects. Example:[
        "id": 12345,
        "fields": [
                "value": "Benjamin"
                "name": "LastName",
                "value": "Verret"
        "id": 23456,
        "fields": [
                "value": "Dianne"
                "name": "LastName",
                "value": "Straka"
 JSON New Record ListDescribes a list of new data records (and their data field values (as name/value pairs)) to be added as data record entities to either an existing data set or data record entity of a specific ID. The structure consists of an objectwith the following name/value pairs: Specific to the adding of data records to the recorddata table of an existing data set entity, an additional name/value pair is included: Specific to the adding of nested data records to a data table of an existing data record entity, two additional name/value pairs are included: Examples:{
    "datasetid": 12345,
    "records": [
            "fields": [
                    "name": "ID",
                    "name": "Gender",
                    "value": "M."
                    "value": "Benjamin"
                    "name": "LastName",
                    "value": "Verret"
            "fields":[
                    "name": "ID",
                    "value": "CU01499303"
                    "name": "Gender",
                    "value": "Miss"
                    "value": "Dianne"
                    "name": "LastName",
                    "value": "Straka"
    "recordid": 12345,
    "table": "detail",
    "records": [
            "fields": [
                    "value": "PSM002"
                    "name": "ItemDesc",
                    "value": "495.00"
                    "value": "2"
                    "value": "990.00"
            "fields": [
                    "value": "PSM005"
                    "name": "ItemDesc",
                    "value": "495.00"
                    "value": "1"
                    "value": "495.00"
 JSON New Record ListsDescribes multiple lists of new data records (and their data field values (as name/value pairs)) to be added as data record entities to either existing data set or data record entities of a specific ID. The structure consists of an arrayof JSON New Record List structureobjects. Example:[
        "datasetid": 12345,
        "records": [
                "fields": [
                        "name": "ID",
                        "name": "Gender",
                        "value": "M."
                        "value": "Benjamin"
                        "name": "LastName",
                        "value": "Verret"
                "fields": [
                        "name": "ID",
                        "name": "Gender",
                        "value": "Miss"
                        "value": "Dianne"
                        "name": "LastName",
                        "value": "Straka"
        "recordid": 12345,
        "table": "detail",
        "records": [
                "fields": [
                        "value": "PSM002"
                        "name": "ItemDesc",
                        "value": "495.00"
                        "value": "2"
                        "value": "990.00"
                "fields": [
                        "value": "PSM005"
                        "name": "ItemDesc",
                        "value": "495.00"
                        "value": "1"
                        "value": "495.00"
 JSON Content Item Identifier ListDescribes a list of content item/data record entity identifier pairs (as name/value pairs) for a specific content set entity. The structure consists of an objectwith the following name/value pairs: Example:{
    "identifiers": [
            "item": 12345,
            "record": 54321
            "item": 23456,
            "record":  65432
            "item": 34567,
            "record": 76543
 JSON Data Record IdentifierDescribes a single data record entity identifier for a specific content item entity. The structure consists of an objectwith a single name/value pair: Example:{
    "record": 12345
 JSON Identifier List (with Email Parameters)Describes a list of identifiers for multiple data entities (specifically data record entities), along with additional parameters used specifically in an content creation operation for email. The structure consists of an objectwith the following name/value pairs:
                                                identifiers- anarrayof data record entity identifiers (type ofnumber)
                                                host- the network address or name of the SMTP mail server through which emails will be sent (type ofstring)
                                                user- the user name to authenticate with (if using authentication) (type ofstring)
                                                password- the password to authenticate with (if using authentication) (type ofstring)
                                                sender- the email address to be shown as the sender in the email output (type ofstring)
                                                useAuth- parameter to specify if authentication is to be used with the mail server (type ofboolean)
                                                useStartTLS- parameter to specify if Transport Layer Security (TLS) is to be used when sending emails (type ofboolean)
                                                useSender- parameter to specify if the sender address will be used as the receiver address for all emails in the output (type ofboolean)
                                                attachWebPage- parameter to specify if a single HTML web page (with embedded resources) of the Web context should also be created and attached to the email output (type ofboolean)
                                                attachPdfPage- parameter to specify if a PDF of the Print context should also be created and attached to the email output (type ofboolean)
 Example:{
    "identifiers": [
        12345,
        23456
    "host": "mail.company.com",
    "user": "johns",
    "password": "password5",
    "sender": "john.smith@company.com",
    "useAuth": true,
    "useStartTLS": false,
    "useSender": true,
    "attachWebPage": true,
    "attachPdfPage": true
 JSON HTML Parameters ListDescribes a list of parameters used specifically in the creation of web content. The structure consists of an objectwith the following name/value pairs:
                                                section- the section within the Web context of the template to use (type ofstring)
                                                inline- the inline mode to be used in the creation of content (value of eitherNONE,CSSorALL) (type ofstring)
 Example:{
    "section": "Section 1",
    "inline": "ALL"
 JSON Job Set StructureDescribes a job set entity structure including the arrangement of job, job segment, document set, document and content item entities (including the specification of content item identifiers). Used specifically in a job creation operation. The structure consists of an objectwith the following name/value pairs: Example:{
    "jobs": [
            "segments": [
                    "documentsets": [
                            "documents": [
                                    "documentpages": [
                                            "contentitem": 111
                                            "contentitem": 222
                                    "documentpages": [
                                            "contentitem": 456
            "segments": [
                    "documentsets": [
                            "documents": [
                                    "documentpages": [
                                            "contentitem": 789
 JSON All-In-One ConfigurationDescribes the configuration of an All-In-One operation as a series of name/value pairs representing the processes (data mapping, content creation, job creation and output creation) to be completed as part of the overall operation. The value in each pair contains the parameters for that specific process. The structure is variable, allowing for configurations containing one or more specific processes (as name/value pairs), as long as the processes specified result in a logical sequence or workflow. Used specifically with the All-In-One service. The structure consists of an objectwith the following name/value pairs:
                                                datamining- data mapping configuration parameters, consisting of anobjectwith the following name/value pairs:
                                                        identifier- the managed file identifier (type ofnumber) or named identifier (type ofstring) of the data file
                                                        config- the managed file identifier (type ofnumber) or named identifier (type ofstring) of the data mapping configuration
                                                contentcreation- content creation configuration parameters, consisting of anobjectwith the following name/value pairs:
                                                        identifiers- anarrayof data record entity identifiers (type ofnumber) (optional for configurations containing data mapping parameters)
                                                        config- the managed file identifier (type ofnumber) or named identifier (type ofstring) of the input design template
                                                jobcreation- job creation configuration parameters, consisting of anobjectwith the following name/value pairs:
                                                outputcreation- output creation configuration parameters, consisting of anobjectwith the following name/value pairs:
                                                        identifiers- anarrayof job entity identifiers (type ofnumber) (optional for configurations containing content creation parameters)
                                                        config- the managed file identifier (type ofnumber) or named identifier (type ofstring) of the output creation preset
                                                        createOnly- flag to specify if output is to be only created in the server and not sent to it's final destination (type ofboolean)
 Specific to the use of all processes (and their parameters), an additional name/value pair can be added to restrict the print output to a set of specific records in the input data: Examples:{
    "datamining":
        "identifier": "Promo-EN-1000.csv",
        "config": "Promo-EN.OL-datamapper"
    "contentcreation":
        "config": "letter-ol.OL-template"
    "jobcreation":
        "config": "4567"
    "outputcreation":
        "config": "5678",
        "createOnly": true
    "printRange":
        "printRange": "1-3, 6, 10"
    "contentcreation":
        "identifiers": [
            34567,
            34568
    "jobcreation": {},
    "outputcreation":
        "config": 5678,
        "createOnly": false
    "datamining":
        "config": 23456
 JSON Page Details SummaryDescribes a summary of the page details for a specific content set entity. Page details include the number of pages per media type, along with media specific properties including the name, size, width and height. Used specifically with the Content Set Entity service. The structure consists of an objectwith the following name/value pairs: Example:{
    "pages": [
            "count": 200,
            "media": {
                "name": "Plain A4 Paper",
                "size": "A4",
                "width": "210mm",
                "height": "297mm"
            "count": 108,
            "media": {
                "name": "Plain Letter Paper",
                "size": "Letter",
                "width": "8.5in",
                "height": "11in"
 JSON Page Details ListDescribes a list of the the page details and identifiers for each content item contained within a specific content set entity. Page details include the number of pages per media type, along with media specific properties including the name, size, width and height. Used specifically with the Content Set Entity service. The structure consists of an arrayofobjectseach with the following name/value pairs:
                                                id- the content item entity identifier (type ofnumber)
                                                pages- a list of the pages per media, consisting of anarrayofobjectseach with the following name/value pairs:
                                                    count- the number of pages using the specific media (type ofnumber)
                                                    media- media specific properties, consisting of anobjectwith the following name/value pairs:
                                                        name- the name of the media (type ofstring)
                                                        size- the size of the media (type ofstring)
                                                        width- the width of the media (type ofstring)
                                                        height- the height of the media (type ofstring)
 Example:[
        "id": 12345,
        "pages": [
                "count": 2,
                "media": {
                    "size": "A4",
                    "width": "210mm",
                    "height": "297mm"
                "count": 1,
                "media": {
                    "size": "Letter",
                    "width": "8.5in",
                    "height": "11in"
        "id": 23456,
        "pages": [
                "count": 2,
                "media": {
                    "size": "A4",
                    "width": "210mm",
                    "height": "297mm"
                "count": 2,
                "media": {
                    "size": "Letter",
                    "width": "8.5in",
                    "height": "11in"
 JSON Data Mapping Validation ResultDescribes the result of a request to validate a data mapping operation, including a list of any errors that occurred (used specifically with the Data Mapping service). The structure consists of an objectwith the following name/value pairs:
                                                result- the overall result of the data mapping operation (value of eitherERRORorOK) (type ofstring)
                                                recordcount- the number of data records in the data file (type ofnumber)
                                                errors- a list of errors that occurred during the mapping process, consisting of anarrayofobjectseach with the following name/value pairs:
 Example:{
    "result": "ERROR",
    "recordcount": 105,
    "errors": [
            "record": 20,
            "reason": "Document: 20 Unparseable date: \"\""
            "record": 45,
            "reason": "Document: 45 Unparseable date: \"\""
            "record": 97,
            "reason": "Document: 97 Unparseable date: \"\""
 JSON Search ParametersDescribes a set of complex search criteria broken into search, sorting and grouping rules. This structure is used specifically with the Entity service as input to the Find Data Entity resource method. Search rules can be added to a search rules list and can be used to match data entities based on specific criteria. This rules list also specifies an operator which determines whether all rules or only one rule in the list is required to be matched. Search rules can be based on data record values, data entity properties,  finishing options, document length, template names and whether an entity's identifier is contained or not contained in a list of identifiers. Rule groups can also be added to this search rules list, and each rule group contains it's own sub list of search rules  and its' own rule operator. Rule groups can also be added to the search rule list of an existing rule group which allows for the construction of complex search criteria. Sorting rules can be also added to a sort rules list and (depending on the data entity type) can be used to sort data entity entries in the search results by either data record values or data entity properties. Every sort rule added will expand the value of the sort key of each entry listed in the resulting JSON Identifier Lists (with Sort Key) structure. Grouping rules can be also added to a group rules list and (depending on the data entity type) can be used to group data entity entries in the search results by either data record values or data entity properties. Every group rule added can expand the number of sub lists contained in the resulting JSON Identifier Lists (with Sort Key) structure. The structure consists of an objectwith the following name/value pairs:
                                                entity- the data entity type (value of eitherDATARECORDS,DATASETS,CONTENTITEMS,CONTENTSETS,JOBSorJOBSETS) (type ofstring)
                                                search- search criteria, consisting of anobjectwith the following name/value pairs:
                                                    operator- the search rule operator for the base list of rules (value of eitherANDorOR) (type ofstring)
                                                    rules- a base list of search rules, consisting of anarrayofobjectseach with a specific rule sub-structure depending on the type of rule
                                                sort- a list of sorting rules, consisting of anarrayofobjectseach with the following name/value pairs:
                                                    name- the name of the data value field or data entity property to sort by (type ofstring)
                                                    order- the order that matches to this rule are sorted by (value of eitherASCorDESC) (type ofstring)
                                                    type- the type of sorting rule (value of eithervalueorproperty) (type ofstring)
 Sorting rule objectswith atypevalue ofvaluealso contain the following additional name/value pair:
                                                group- a list of grouping rules, consisting of anarrayofobjectseach with the following name/value pairs:
                                                    name- the name of the data value field or data entity property to group by (type ofstring)
                                                    order- the order that matches to this rule are grouped by (value of eitherASCorDESC) (type ofstring)
                                                    type- the type of grouping rule (value of eithervalueorproperty) (type ofstring)
 Grouping rule objectswith atypevalue ofvaluealso contain the following additional name/value pair: The search rule sub-structure consists of an objectwith rule specific groupings of name/value pairs as follows.
                                            Search rule objectswith atypevalue ofvaluecontain the following name/value pairs:
                                                    type- the type of search rule (value ofvalue) (type ofstring)
                                                    name- the name of the data field (type ofstring)
                                                    value- the value of the data field (type ofstring, orarrayofstringswhenconditionis value of eitherINorNOT IN)
                                                    condition- the comparison condition (value of eitherEQUAL,NOTEQUAL,LESS,GREAT,LESSEQUAL,GREATEQUAL,STARTSWITH,ENDSWITH,CONTAINS,LIKE,NLIKE,INorNOT IN) (type ofstring)
 Search rule objectswith atypevalue ofpropertycontain the following name/value pairs:
                                                    type- the type of search rule (value ofproperty) (type ofstring)
                                                    name- the name of the data entity property (type ofstring)
                                                    value- the value of the data entity property (type ofstring, orarrayofstringswhenconditionis value of eitherINorNOT IN)
 Search rule objectswith atypevalue of eitherINorNOT INcontain the following name/value pairs:
 Search rule objectswith atypevalue offinishingcontain only one of the following sub-groups of name/value pairs:
                                                    type- the type of search rule (value offinishing) (type ofstring)
                                                    medianame- the name of the media used (type ofstring)
                                                    condition- the comparison condition (value of eitherEQUALorNOTEQUAL) (type ofstring)
                                                    frontcoating- the front coating of the media used (value of eitherUNSPECIFIED,NONE,COATED,GLOSSY,HIGH_GLOSS,INKJET,MATTE,SATINorSEMI_GLOSS) (type ofstring)
                                                    backcoating- the back coating of the media used (value of eitherUNSPECIFIED,NONE,COATED,GLOSSY,HIGH_GLOSS,INKJET,MATTE,SATINorSEMI_GLOSS) (type ofstring)
                                                    bindingstyle- the binding style of the media used (value of eitherNONE,DEFAULT,STAPLED,GLUED,STITCHED,ADHESIVE,SPINETAPING,RING,WIREDCOMB,PLASTICCOMBorCOIL) (type ofstring)
                                                    bindingedge- the binding edge of the media used (value of eitherDEFAULT,LEFT,RIGHT,TOPorBOTTOM) (type ofstring)
                                                    bindingtype- the binding type of the media used (value of eitherDEFAULT,SADDLE,SIDEorCORNER) (type ofstring)
                                                    bindingangle- the binding angle of the media used (value of eitherDEFAULT,VERTICAL,HORIZONTALorANGLE) (type ofstring)
 Search rule objectswith atypevalue ofdoclengthcontain the following name/value pairs:
                                                    type- the type of search rule (value ofdoclength) (type ofstring)
                                                    value- the number of pages in document (type ofnumber)
                                                    condition- the comparison condition (value of eitherEQUAL,NOTEQUAL,LESS,GREAT,LESSEQUALorGREATEQUAL) (type ofstring)
 Search rule objectswith atypevalue oftemplatenamecontain the following name/value pairs:
                                                    type- the type of search rule (value oftemplatename) (type ofstring)
                                                    template- the name of the design template used for document (type ofstring)
 Search rule group objectscontain the following name/value pairs:
                                                    operator- the search rule operator for sub-list of rules in rule group (value of eitherANDorOR) (type ofstring)
                                                    rules- a sub-list of search rules, consisting of anarrayofobjectseach with a certain rule sub-structure depending on the type of rule
 Examples:{
    "entity": "CONTENTITEMS",
    "search": {
        "operator": "AND",
        "rules": [
                "type": "value",
                "value": "FR",
                "name": "Country"
                "operator": "OR",
                "rules": [
                        "type": "finishing",
                        "frontcoating": "HIGH_GLOSS",
                        "backcoating": "HIGH_GLOSS",
                        "condition": "EQUAL"
                        "bindingstyle": "DEFAULT",
                        "bindingedge": "DEFAULT",
                        "bindingtype": "DEFAULT",
                        "bindingangle": "VERTICAL",
    "sort": [
            "name": "LastName",
            "order": "ASC",
            "numeric": false,
            "type": "value"
    "group": [
            "name": "Gender",
            "order": "ASC",
            "numeric": false,
            "type": "value"
 JSON Identifier Lists (with Sort Key)Describes a set of search results as a list of one or more sub lists,  each containing a list of data entity identifiers along with a sorting key value for each entry. Used specifically with the Entity service as the output from the Find Data Entity resource method, this structure groups the data entity identifiers returned into sortable sub lists of entries. The order of the entries (including the sort key produced), and the number of sub lists returned depends on the sorting and grouping rules specified in the JSON Search Parameters structure previously submitted as input to the Find Data Entity resource method. The structure consists of an arrayofobjectarrays, with eachobjectcontaining the following name/value pairs: Example:[
            "identifier": 1604,
            "sortkey": "NB|Vilma"
            "identifier": 1282,
            "sortkey": "NF|Lenard"
            "identifier": 1443,
            "identifier": 1000,
            "sortkey": "SK|Cathleen"
            "identifier": 1121,
            "sortkey": "SK|Rachel"
 JSON Operations ListDescribes a list of workflow operations (specifically asynchronous workflow operations) actively running on the server, each containing various properties including the type of workflow operation, it's starting time and it's current progress value. This structure is used specifically with workflow based services including the Data Mapping, Content Creation, Content Creation (Email), Job Creation, Output Creation and All-In-One services. The structure consists of an arrayofobjectseach with the following name/value pairs:
                                                id- the workflow operation identifier (type ofstring)
                                                type- the workflow operation type (value of eitherDataMiningRestService,ContentCreationRestService,EmailExportRestService,JobCreationRestService,OutputCreationRestServiceorPrintRestService) (type ofstring)
                                                subTask- the workflow operation sub-task name (type ofstring)
                                                startTime- the workflow operation starting time stamp (value of milliseconds since midnight of January 1, 1970 UTC) (type ofnumber)
                                                progress- the workflow operation progress percentage (value in range of0to100) (type ofnumber)
 Workflow operation objectswith atypevalue of eitherContentCreationRestServiceorPrintRestService(usually with asubTaskvalue ofContent Creation) can also contain the following name/value pair: Example:[
        "id": "1281ef9d-7a74-4448-9adf-175a0166f32e",
        "type": "DataMiningRestService",
        "subTask": "Extracting data 25%",
        "startTime": 1482367446908,
        "progress": 100
        "id": "b72e2da5-39ea-48de-85cf-a2be321a71bd",
        "type": "ContentCreationRestService",
        "subTask": "Content Creation",
        "startTime": 1482367988332,
        "progress": 12,
        "template": "business-card-ol"
        "id": "134f55a5-85f5-41d5-a0d3-e033eda45cb5",
        "type": "EmailExportRestService",
        "startTime": 1482368638197,
        "progress": 5
        "id": "d52cf2b6-9ca7-44e6-b548-5b249dedf40d",
        "type": "JobCreationRestService",
        "subTask": "Job Creation",
        "startTime": 1482367723483,
        "progress": 77
        "id": "02fa495b-ed56-47ef-ac49-e63df298b10e",
        "type": "OutputCreationRestService",
        "subTask": "Output Creation",
        "startTime": 1482367851340,
        "progress": 34
        "id": "fb414be9-4ec5-463a-8429-93153db73783",
        "type": "PrintRestService",
        "startTime": 1482366891203,
        "progress": 65,
        "template": "letter-ol"
