Getting Started
This guide provides many working examples to help illustrate the correct use of a given API/method. To achieve this, the guide uses HTML5 & JavaScript/jQuery syntax, and thus, some basic experience and knowledge of these technologies is assumed.
Help on installing and getting started with the working examples can be found on the Requirements & Installation and Structure of the Working Examples pages.
Important notes on general use of the working examples can be found in the HTML Input Placeholders & Multiple Value Fields and Display of Working Example Results pages.
If you have server security settings enabled on your PReS Connect server then the Using the Working Examples with Server Security page should be read also.
