Run +PReS Enhance Workflow Configuration
Submits a request to run a +PReS Enhance workflow configuration via the Weaver engine directly, using a list of command-line arguments.
Request takes no content, and on success returns a response containing the result of the request to run/execute the workflow configuration.
Type: GET
URI: /rest/serverengine/workflow/outputcreation/execute/{args}/{size}
Parameters:
Path:
Request:
Add. Headers: auth_token – Authorization Token (if server security settings enabled)
Content:
Content Type:
Response:
Add. Headers:
Content: Result of request to run +PReS Enhance workflow
Content Type: text/plain
Status:
  • 200 OK – +PReS Enhance Workflow Configuration successfully run/executed
  • 401 Unauthorized – Server authentication required
  • 403 Forbidden – Server authentication has failed or expired
