Cancel an Operation
Requests the cancellation of a running All-In-One operation of a specific operation ID.
Request takes no content, and on success returns a response with no content.
Request
| Method Type: |
POST |
| URI: | |
| Content: | – |
| Content Type: |
| Add. Headers: |
Parameters
Path parameters
| Name | Required | Type | Default Value | Description |
| operationId |
Operation ID of All-In-One operation |
Response
Success
| 204 No Content |
Operation cancellation requested |
Error
401 Unauthorized |
Server authentication is required. Response when neither basic authentication credentials nor an authorization token have been specified in the request headers. |
401 Unauthorized |
Error message |
Server authentication has failed. Response when the authorization token specified in the request headers has now expired. |
403 Forbidden |
Error message |
Server authentication has failed. Response when either the basic authentication credentials or the authorization token specified in the request headers are invalid. |
404 |
text/plain |
Operation not found in Server |
