Process All-In-One (JSON)
Submits a request to initiate a new All-In-One operation.
Request takes a JSON All-In-One Configuration as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
| Method Type: |
POST |
| URI: | |
| Content: | JSON All-In-One Configuration containing workflow processes/parameters |
| Content Type: |
application/json |
| Add. Headers: |
Response
Success
| 202 Accepted |
Error
400 |
Required Input resource/file not found in File Store |
401 Unauthorized |
Server authentication is required. Response when neither basic authentication credentials nor an authorization token have been specified in the request headers. |
401 Unauthorized |
Error message |
Server authentication has failed. Response when the authorization token specified in the request headers has now expired. |
403 Forbidden |
Error message |
Server authentication has failed. Response when either the basic authentication credentials or the authorization token specified in the request headers are invalid. |
500 |
General error with running the All-In-One Process or a specific error relating to an individual workflow process (see error description) |
