Process Content Creation (By Data) (JSON)
Submits a request to create new HTML content for the Web context.
Request takes a JSON Record Data List of the data values for the Data Record as content, and on success returns a response containing the HTML output produced, specific to the record data and parameters specified.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/html/{templateId} |
Content: | JSON Record Data List specifying a list of data values for the Data Record |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
templateId |
Query
section |
Default section in template |
inline |
NONE |
The inline mode to be used in the creation of content (Possible values: NONE, CSS or ALL.) |
cssSelector |
No |
String |
A CSS selector for the creation of only a specific HTML element within the template |
Response
Success
200 OK |
The entire HTML output for the Data Record, or the inner HTML of the first element that matches the given CSS selector, or an empty string if the CSS selector produced no results | text/html | – | Output created successfully |
Error
401 Unauthorized |
Server authentication is required. Response when neither basic authentication credentials nor an authorization token have been specified in the request headers. |
401 Unauthorized |
Error message |
Server authentication has failed. Response when the authorization token specified in the request headers has now expired. |
403 Forbidden |
Error message |
Server authentication has failed. Response when either the basic authentication credentials or the authorization token specified in the request headers are invalid. |
404 |
500 |
