Find Data Entity
Submits data entity search criteria to the PReS Connect Server.
Request takes a JSON Search Parameters structure as content and on success returns a response containing JSON Identifier Lists (with Sort Key) of the data entity IDs matching the search criteria.
| Method Type: |
PUT |
| URI: | |
| Content: | JSON Search Parameters containing search criteria/rules |
| Content Type: |
application/json |
| Add. Headers: |
Response
Success
| 200 OK |
JSON Identifier Lists (with Sort Key) containing all the entities matching the search criteria | application/json | – | Search request successfully executed |
Error
401 Unauthorized |
Server authentication is required. Response when neither basic authentication credentials nor an authorization token have been specified in the request headers. |
401 Unauthorized |
Error message |
Server authentication has failed. Response when the authorization token specified in the request headers has now expired. |
403 Forbidden |
Error message |
Server authentication has failed. Response when either the basic authentication credentials or the authorization token specified in the request headers are invalid. |
500 |
Server error or Invalid JSON structure specified |
