Create Preview Image (By Data) (JSON)
Submits a request to create a preview image of the print, email, or web output for a single data record.
Request takes a JSON Record Data List (with Image Parameters) of the data values for the Data Record as content, and on success returns a response containing the image output produced, specific to the record data and parameters specified.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/imagepreview/{templateId}
Content: JSON Record Data List (with Image Parameters) of the data values for the Data Record
Content Type:
application/json
Add. Headers:
Parameters
Path Parameters
templateId
Yes
String
  • The Managed File ID (or Name) of the template in File Store
  • Response
    Success
    200
    OK
    Preview Image
    image/jpeg
    Creation of a preview image successful.
    Response when the image parameters specified contain:
    • a type value of JPG or JPEG
    • an archive value and pages value that would result in a single page
    200
    OK
    Preview Image
    image/png
    • a type value of PNG
    200
    OK
    Preview Images (Zipped)
    application/zip
    Creation of preview images successful.
    • an archive value and pages value that would result in a multiple pages
    Error
    400
    Bad Request
    Context not found / Section not found
    401 Unauthorized
    Server authentication is required.
    Response when neither basic authentication credentials nor an authorization token have been specified in the request headers.
    401 Unauthorized
    Error message
    Response when the authorization token specified in the request headers has now expired.
    403 Forbidden
    Error message
    Response when either the basic authentication credentials or the authorization token specified in the request headers are invalid.
    404
    Not Found
    JSON Error specifying error message
    application/zip
    Template found in File Store
