Get Result of Operation
Retrieves the final result of a completed Content Creation operation of a specific operation ID.
Request takes no content, and on success returns a response containing the IDs of the Content Sets produced.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/getResult/{operationId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
operationId |
Operation ID of Content Creation operation |
Response
Success
200 OK |
Content Set IDs |
text/plain | – | Result of completed operation successfully retrieved |
Error
400 |
Context not found / Section not found |
401 Unauthorized |
Server authentication is required. Response when neither basic authentication credentials nor an authorization token have been specified in the request headers. |
401 Unauthorized |
Error message |
Server authentication has failed. Response when the authorization token specified in the request headers has now expired. |
403 Forbidden |
Error message |
Server authentication has failed. Response when either the basic authentication credentials or the authorization token specified in the request headers are invalid. |
404 |
text/plain |
Operation not found in Server |
