Get Multiple Data Record Values (JSON)
Returns a list of the values for one or more Data Record entities, and potentially the values of any nested Data Records (if recursive).
Request takes a JSON Data Record Identifier List (with Parameters) of the Data Record IDs as content, and on success returns a response containing either:
- JSON Record Content Lists of all the values for each Data Record
- JSON Record Content Lists (Explicit Types) of all the values and data types for each Data Record
Request
| Method Type: |
POST |
| URI: | |
| Content: | JSON Data Record Identifier List (with Parameters) specifying the Data Record entity IDs |
| Content Type: |
application/json |
| Add. Headers: |
Response
Success
| 200 OK |
JSON Record Content Lists of the values for each Data Record | application/json | – | Data Record entity values successfully retrieved |
| 200 OK |
JSON Record Content Lists (Explicit Types) of the values and data types for each Data Record | application/json | – | Data Record entity values and data types successfully retrieved |
Error
401 Unauthorized |
Server authentication is required. Response when neither basic authentication credentials nor an authorization token have been specified in the request headers. |
401 Unauthorized |
Error message |
Server authentication has failed. Response when the authorization token specified in the request headers has now expired. |
403 Forbidden |
Error message |
Server authentication has failed. Response when either the basic authentication credentials or the authorization token specified in the request headers are invalid. |
500 |
Server error or invalid Data Record ID specified |
