Rasterize File
Converts a PDF, PS, AFP or PCL file into a bitmap. The conversion can be done for a single page or for multiple pages.
Request takes JSON Bitmap Parameters JSON Bitmap Parameters as content, and on success returns the converted page as a PNG or JPEG file, or returns a ZIP file with the converted images (PNG/JPEG) if rasterization is requested for more than one page.
Request
Method Type: |
POST |
URI: | |
Content: | JSON Bitmap Parameters |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
dataFileId |
Yes | Number | – |
The Managed File ID (or Name) of a PDF, PS, AFP or PCL file in the File Store |
Response
Success
200 OK |
A stream with a JPEG/PNG image or a ZIP file with JPEG/PNG images | application/zip, image/jpeg, or image/png | Bitmap creation successful |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
ID of uploaded PDF, PS, PCL, or AFP data file cannot be found in filestore |
