Find Data Entity
Submits data entity search criteria to the PlanetPress Connect Server.
Request takes a JSON Search Parameters structure as content and on success returns a response containing JSON Identifier Lists (with Sort Key) of the data entity IDs matching the search criteria.
Method Type:
PUT
URI:
/rest/serverengine/entity/find
Content: JSON Search Parameters containing search criteria/rules
Content Type:
application/json
Add. Headers:
Response
Success
200
OK
JSON Identifier Lists (with Sort Key) containing all the entities matching the search criteria application/json – Search request successfully executed
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
Server error or Invalid JSON structure specified
